BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Fri Oct 28, 2005 4:24 pm
I've seen an S14 on 19" wheels. Not sure if the fenders had to be rolled, but I wouldn't be surprised. As for tire size, I have no idea. You may want to have this topic moved to the Tire & Suspension forum.
So, yes, it can be done, depending on the size and offset of the wheel.
Keep in mind that these wheels are probably going to weigh a ton and actually make your car slower. Also, the low profile tires you'll need to run will make you more susceptible to pot hole damage.
