JRL »
https://forums.nicoclub.com/jrl-u26048.html
Wed Apr 06, 2005 2:15 pm
I have the same problem.
The closer I set my timing to 15 degrees, the closer my idle gets to 700 rpm.
At 20+/- 2 degrees as it recomends in the FSM, my idle will go no lower than 750, although I can get it well above 1000 by adjusting the AIV.
An odd thing I noticed when you look at the base timing map for an S13 KA.
The timing in the 1st square is 15, this is your base timing that your ECU uses when its under no load (idle). At idle, the your ecu access only the first cell on the map.
Once under load, your ecu uses the average of 4 cells. 2 upper cells, and, 2 lower cells. Which your first 4 cells average out to 17.5 degrees....which is exactly where the FSM shows the timing needle in the diagram in the FSM.
So I set my timing just in front of the second to last timing mark and it idles near perfect.
