can the brembo brakes be swapped onto the 2003 g35 sedan
ptrpn3283
Car: g35 sedan
I haven't seen anywhere or just blind but can the brembo brakes be put on to the 2003 g35 sedan.
soul_hfk
Car: 2010 G37xS---08 QX56
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Yes they can. It's a direct fit as long as you get everything with the brembo kit. You can also swap the 2005 G35c standard brakes as well. They are 2 piston caliper front with 12.6" rotor. I put those on my sedan for $190 for everything. The rotors are almost the same size as the brembo rotor. This is still an upgrade since the stock caliper is only single piston. I have noticed better stopping and NO more dust.
The brakes on the 05 RWD sedan have been revised along with the 06 X sedan. Same setup as the coupe.
Crashtest77
Car: 2003 G35 coupe
That's good to know Red. I just might do the two piston set swap. Cheaper than the stinkin brembo's, although they would be nice.
