Can the AT diagnosis show problems?
longrunQ
Car: music
Or is it just checking that sensors are working?
I was wondering if the onboard diagnosis could tell if you AT lines were clogged, leading the transmission to overheat
PalmerWMD
Car: 2004 350Z
longrunQ wrote:I was wondering if the onboard diagnosis could tell if you AT lines were clogged, leading the transmission to overheat
No.the way to check for clogged lines and the resulting problems is a line pressure check.
Fred...:)
