can the angel eye mod be done to the J?
j30t
check out this site. http://www.geocities.com/jvxdriver/eagle_eyes.htm looks pretty cool and seems easy to do. anyone ever try this? How hard is it to take about the light assembly? Any instructions on doing so? And where would i connect the wires to get them to light up? Seems like a cool mod for the Js projection headlights.
Problem is the shiny reflective housings scatter the light, ruining the "halo" effect.
Considered doing it for the Q (just for fun) but I saw a car with reflective housings and the halo effect was all but lost.
Eswift
Car: should be obvious enough
could be done similarly to how that kid did it, without much difficulty. true about the reflective housing, but you could just -hi temp paint the chrome part of housing flat black to compensate. would look very slick on the J in my opinion, i had the same idea a while back.
Eswift
just paint the inside of the housings flat black, and then shave the turnb signals and paint over it in the stock body colour. hook up the front amber running lamps as turn signals, and your pretty much even road legal. would look something like this.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
If something like that was done to a Q, it would look pretty much like a BMW.
Eswift
except missing the kidney grille and special hood shape. sort of how like ford ripped off the 5 series for its lincoln LS.
j30t
yea...so you think its possible to do? can you explain this
and then shave the turn signals and paint over it in the stock body colour. hook up the front amber running lamps as turn signals, and your pretty much even road legal. would look something like this.
Im not really sure what you mean by that. Also, how hard is it to open up the light housing?
Eswift
dont have a J30 handy here, look at your own headlights. very well might be that same thermoplastic adhesive as that kid discussed.
i was simply explaining what would have to be done to make the j30 in the picture i attached look like that, and to make it road legal.
j30t
could i just get a switch...like for the neon lights that some people use...and run that to the halos to make them light up? seems like an easy way to do things. im just most worried about getting the headlights apart.
Eswift
tap them into the parking light wires, instead.
elwesso
2007 BMW M Coupe
Was that a photoshop??? If so, could you do one for a Q???
j30t
it could maybe look sort of like this. Dont laugh at it. Best i could do with what i had. Last picture... http://www.cardomain.com/id/silverj30t
Eswift
nothing fancy. MS Paint.
Eswift
i like the looks of that j30t. here's a direct:
baco99
those would look great on the j30!
Omar
Car: cars, computers, fashion, my friends
Hey, No offense but those painted lenses next to the headlights look ugly. It takes away the beauty, dont you think?
Take care.
Later...
j30t
what painted lenses? in the picture? thats because thats the only example i coudl make...the would light up like the BMW angel eyes if i were to do it.
Eswift
Omar wrote: No offense but those painted lenses next to the headlights look ugly. It takes away the beauty, dont you think?
as stated earlier, the purpose is to make the angel eyes brighter. without flat black paint on the inside of the assembly, the eyes wont stand out as well.
as for the shaved turn signals, its a matter of taste. the reasons behind is because if the inside of the headlisght assembly is made dark, you then have a floating turn signal, which looks even worse.
maccj73
How about just painting a black ring directly behind where you would mount the rings of the angel eyes? Then you wouldn't have the floating turn signal problem. And if you etch the back of the plastic rings the light will refract to the front. The reflective housing shouldn't affect it THAT much. This could only be proven by trying it first.
Eswift
good ideas, but a test would be necessary, in all cases.
maccj73
Easily tested via junk yard parts, that way you don't take a chance on messing up yours.
Eswift
good luck finding J30 headlamps for less than 100 dollars each.
j30t
well im going to be doing it within the week once i get the LEDs...hope i dont mess anythign up.
Eswift
good luck, we of course will expect progress updates!
willisbr
Car: Cars, Law, Government, Family
To answer all questions in this string so far...the glass or "reflective" housing does not diminish the halo effect. I have a set of Angel Eyes on my J that I did myself and they work perfectly.
Tap into your parking lights. Don't make them blinkers.
Don't paint your housings black because then you ruin the chrome concept of your J. Stay with your luxury apperance...don't permenantly modify your car that much just for a set of lights.
Check out my car and send my ya'lls picks to...later! :)
cardomain.com/id/willisbr
