I initially tried that, but I only gave the wheel a slight pull. I was kind of afraid I might have damaged it if I put more strength into it. But if the steering wheel is locked, is that the reason why the little button near the ignition wouldn't push down either?ddgsxr504 wrote:Is your steering wheel locked?? If so give it a hard pull in either direction while turning the key.
