yearoftherat wrote:That's odd. When I plug in my iphone to the USB plug, the the screen changes to "ipod" and I can play music. Can be done even when I do not have bluetooth enabled too.
I can have both bluetooth on and plug it in through the USB port and music will play through whichever input I select.CanuckD wrote:I have a 2015 Rogue SL with Navi and an <a class="vglnk" title="Link added by VigLink" target="_blank" href="http://www.ebay.com/sch/i.html?_odkw=ip ... 5&_sacat=0" rel="nofollow"><span>Iphone </span><span>5</span></a> (IOS 7.1.2).
- I can stream music via bluetooth from the iphone to the car using a music app (ex: songza) with no problems.
- But If i want to charge the phone at the same time via USB port, the car won't let me stream via bluetooth anymore. It says USB connection is enabled but I can't hear any music from the car.
I've tried installing nissan connect to see if that helps but still same issue.
How do i get the music to stream from my app and charge via USB at the same time with my iphone?? I must be missing a step somewhere??
Thanks in advance!
