GoTRicEo0 »
https://forums.nicoclub.com/gotriceo0-u37733.html
Sat Jan 20, 2007 5:14 pm
While the Brake is applyed during heavy boost, the car instantly dies. Seems I have a Boost leak somewhere around the SMIC which could be causing all these problems.Idle can't be adjusted by the screw next to the injectors also. No matter how far you turn it left or right, idle is the same. Bounces around 900-1100 once n awhile.
I'll check more on it 2marrow~Jeff
(After thinking more about the brake killing the engine during peak boost, could that've been caused from bad/or faulty wiring? The more I think about it, I dont see how a car running around 3-4k just die from just hitting the brake.)
Modified by GoTRicEo0 at 8:15 PM 1/20/2007
