rewjr69 »
https://forums.nicoclub.com/rewjr69-u160187.html
Wed May 19, 2010 6:33 am
1990 300zx na
My car has been sitting down for 6 years, got the engine going again. Everything works perfectly but the brakes. Went to bleed brakes and discovered BMC has a leak in between the ports.
Tried to change the bmc out but the nuts that hold the brake lines are practically fused shut. Any suggestions on what tool I can use to loosen them?? FYI, I used an open ended 10mm wrench and a vice grip to no avail.
