Can't raise quarter windows after putting top back up...
volvox
Call me a nOob, but my girlfriend just brought a used 93 Nissan 240sx convertible, and we went to put the top down today. Well, the Quarter windows lowered when she hit the top down button but we have not been able to get them to raise, either with the top up button or the either of the quarter window buttons on the panel between the seats. Infact- those don’t seem to do anything. No noise or anything. Any ideas anyone? Help?
Harman850T5
Car: 2003 350z
Did you make sure the window lock button isn't pressed? It happens.
You could pull the center console and make sure the switches are still connected to the harness.
Hopefully it's one of those, or maybe a fuse.
onosqv
Car: '92 240sx Vert
If you are still having problems (and it's not the window lock button)...
are the driver side & passenger side front windows also not working? - i.e. only going down, but not up? If so, then your power window amp (located behind the back seat for s13 verts) is probably out, that's what happened to mine.
Piper
Car: 96 240, the new toy.
93 Vert, gave to my bro... for now,
91 HB, brother totaled,
27 other 240sx's in total, all gone now!
onosqv wrote:If you are still having problems (and it's not the window lock button)...
same thing with mine. i just smacked it around alittle and it is working fine now. that was about 2 years ago.
pohaku
My quater windows dont go up or down.Whats the chances that both window motors are dead?Could it be this power window amp of which you speak.Front windows work fine.
onosqv
Car: '92 240sx Vert
The switch for the rear quarter windows have also been known to go bad. If the power amp goes out, it usually affects all windows.
I believe someone here uploaded the Convertible Supplement FSM that you can d/l and go thru troubleshooting steps.
smh240sx
I had the same problem with my vert when i bought is "THAT WHAT I GET FOR PUTTING THE TOP DOWN AND THEN NOT PUTTING IT BACK UP BEFORE HANDING OVER CASH" anyway i checked everything and cant figure it out found a used switch and switched them out and solved my problem.
S15nS13vert
Car: 95 240sx with a s15 engine 6speed transmission, 94 S13.4 SKYLINE VERT and a 08 Lexus RX350
i put a new 1/4 window switch and they now work fine
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
Mine go down fairly quick but go up really slow. They wiggle around alot maybe they are trying to come up but just got out of wack enough that they aren't coming back up.
wmdavis007
Car: 1992 240SX Convertible
1997 Jeep Wrangler Sahara 4.0L
volvox wrote:Can't raise quarter windows after putting top back up...Call me a nOob, but my girlfriend just brought a used 93 Nissan 240sx convertible, and we went to put the top down today. Well, the Quarter windows lowered when she hit the top down button but we have not been able to get them to raise, either with the top up button or the either of the quarter window buttons on the panel between the seats. Infact- those don’t seem to do anything. No noise or anything. Any ideas anyone? Help?
Same thing happened to me. But after freakin' out for about 20 mins before a big rain storm I remembered the window lock button on the drivers side door. Pushed it and they came up fine. Think more then two dozen of us on here have done the same thing. Hope you get it fixed.
pohaku
after pulling the speaker covers off,my quater windows were just unplugged.pass.side works great,drivers side is off track.seems to be a common problem.I'm starting to really dig this car,now that the bugs are getting worked out.thanks to the wealth of info on this site.
onosqv
Car: '92 240sx Vert
Azrial wrote:Mine go down fairly quick but go up really slow. They wiggle around alot maybe they are trying to come up but just got out of wack enough that they aren't coming back up.
That's your guides - you can look @ the write up on how to replace all 3 somewhere on this subforum (I believe if you search "rear window" or "rear window guides" you should find it fairly quickly).
corysnismo
Car: 93 s13 vert
wow thats some good s***...so this happened to me today and after takin most of the car apart.it got dark and cold and i gave up until 2maro... i hope its something easy like that even tho imma feel like a rere... im lovin the new s13 vert tho and tryin not to trade it for a hard top lol theres just alot to the verts... s***s crazyyyy
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
WAIT!!!! Should they raise when you puch the top up button? Wtf? I have to do mine after the top is closed!
wmdavis007
Raised this thread from the dead didn't you...hehe. Like others have noted, first: make sure your window lock button is not pushed in on the drivers side window controls...if it is, when the top is lowered the windows will lower but will not come back up at the quarter window switch until you unlock the windows. Second: it could be your quarter window switch...these switches tend to fail...my first switch had to really be pushed hard to get them to go up. Lastly: it could be your power window amp behind the rear seat...some have said you can tap it with a screwdriver or something while trying the switch and you may get them up...or it may need replacing.
s13beast wrote:WAIT!!!! Should they raise when you puch the top up button? Wtf? I have to do mine after the top is closed!
No...they do not raise when the top is closed...you have to bring the windows up at the switch. They lower so they don't get damaged while the top is in motion.
Hope this helps and clears up a few things .
corysnismo
Car: 93 s13 vert
wooow so the door window switch was lose... when i went to take it apart i heard it get power and problem solved.... thanx guys
wmdavis007
Very cool! Glad to hear you got them working.
