Long post coming up, brace yourself!
DJBeasy wrote:Tracking meaning steering on its own in a way. Feels like the car gets caught in a track and you have to correct your steering a lot to stay in a straight line.
My car's had tracking issues ever since I got my new wheels and I thought it was just due to the camber I was running.
DJBeasy wrote:As for noises, on the passenger side its sounds like a low pitched rumble or grinding/rubbing sound. Like I said earlier, I can only explain it as NOM NOM NOM but with a W, so WOM WOM WOM haha! I also had a high pitched clicking, metal to metal sound on the driver side. That was also the bearing, just not in as bad shape as the passenger side.
Oh yeah you told me this already my bad. Man when it was raised I didn't have any noises but now that its back down I'm back to square one... I wonder if this means its actually related to my struts or if the noise went away because less stress was being put on the bearings due to the car being higher..
Actually, I've been hearing this other noise for a while too. I'm using true style coilovers so nothing is in the spring bucket and it naturally rattles. But for about two weeks I've been hearing what sounds like a grumble (only at high speeds like 60+). I thought it was a noise part of the rattling that had always been there and I just started noticing it but now I'm thinking it might be tied to the wheel bearing. But the sounds are coming from opposite ends of the car...
DJBeasy wrote:They quoted me $980 for parts and labor to do both. I am NOT going to pay that. I need to go down there and see exactly what it is they are quoting me on parts wise and then jump over to courtesyparts.com to get better prices and make them match. They said $250 per hub and then $480 in labor. Im having them do some other things as well so the labor should come down.
I think maybe I should continue riding on it before I cough up that much money that may or may not fix the problem. As time goes by the noise should become more apparent and hopefully point me in the right direction. There's still other possibilities for me like grease on the brake pads or something. I wanna take it back to the dealer and ask them to check out my hub bearings but last time they said they would charge me $50 to look at my car since it had aftermarket suspension components. And by the end of the visit the rate had gone up to $110 after speaking with a tech. Maybe I'll try another dealer.
Does anyone know what could cause the bearings to go bad so quickly? My car only has 20k miles... How many miles do you have, DJ?
Eriko wrote:Ok thanks thats what I did but I think I preloaded more than what I was supposed too. Is thier anything wrong with having too much preload?
Your spring would just be compressed more and your ride may be more stiff than at a preload of 0. But other than that there shouldnt be any downsides.
