teddy »
https://forums.nicoclub.com/teddy-u22985.html
Sun Jun 25, 2006 1:08 pm
Having some problems with the CA. This is the first time I've run the car in over a year. I can't get it to idle at all. If I let off the gas, the rev's will just fall off and die. This is all in neutral. I've tried adjusting the idle screw to no avail. Maf is functioning fine, and is placed far enough away from the turbo. I am running an open downpipe and am backfiring if I rev it up, so I'm wondering if it's running rich. Here's the modst3/t04efmicstock maflightweight flywheelhks filter255 fuel pumpstock injectorse-manage
Now I know the t3 is going to suck in a lot more air than the stock t25, but I didn't think it'd be much more at idle. Still running on the stock fuel maps, and stock fpr, but if there was too much air, this would contradict the backfiring.
I know the timing belt is on correct, and I've toyed with the cas a little, but doens't make a difference. I am also runnign a vented bov, but didn't think that would affect the car drastically at idle. Here's the kicker. The car runs great other than dying when I let off the gas. It starts right up, doesn't run rough, doesn't leak anything and isn't smoking. It ran great last summer too, and idled, but I wasn't putting boost through it. I can also rev freely. It has some year old gas in it, but I put stabilizer in it last year, and just added 2 gallons of 93 with some seafoam to it.
So, any ideas?
