Another way to think of it...... you can spend a lot of money (keeps adding up) fixing the alignment, but you can also keep buying inexpensive tires, rotate often (including side to side), and replace at 20K miles.
My left rear alignment has been off forever from hitting a curb in ice, after replacing several control arms and bearing the rear camber is at 0 (should be -1, I think). But doesn't bother me as long as I can get strong Yokohama tires for $45-70 each!!!
The steering isn't as sharp as it was from the factory, so I'd never really know if it was aligned perfectly anyways!
