I sent the day deciphering the pinouts for the 99 maxima ecu, and finally figured out what I needed.
i connected everything in this order...
bee-r - ecu - pin#
red wire - switched 12+ - pin#31black wire - ground - Pin#32yellow wire - 1' crank sensor - pin#49green wire - 120' crack sensor - pin#46
The Bee-R module is lighting up, so its getting power. But when I test it by setting the limit to 2500, it doesn't cut ignition. Any ideas? Does anyone know of a bee-r limited vq30de maxima?
