Can't get fuel pressure to go down
chad-s12-drift
Car: 85 niss. 200sx ca18det swap
I have had a walbro and nismo sr fpr in my car fo a while with no problem. I just put in a z32 maf and rx7 460 injectors with Rs Enthalpy tune and the car has 80 psi fuel pressure. I took the rail and line back off and blew air threw them there are no clogs or kinks yet with the fpr all the way loose it still has 80 psi. I don't see how the different injectors would make the pressure jump like that the only thing controlling pressure is the fpr right?
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
yes the FPR is the only thing, are you setting fuel pressure with the vacuum line disconected from the fpr
float_6969
I think you have the fuel feed and returns lines switched. If you run fuel through the FPR backwards it "dead heads" the fuel pump. Fuel path should be:
Fuel Pump->Fuel Filter->Fuel Rail->Fuel Pressure Regulator->Return line to Tank
chad-s12-drift
As soon as I turn the key to acc. it goes to 80psi and stays there even when the engine is running and the fpr is all the way loose . Also the fuel lines weren't disconnected when the new injectors were first put in I wish that was the fix lol. I don't see why different injector would make it spike up like that. It shouldnt make the rail pressure change only the fpr should which was working fine unless it a coincidence that it happen to go bad right then.
TheMAN
like float said... if you hooked up the fuel lines wrong, it can do this
float_6969
If you're sure the lines weren't disconnected, then you either have an obstruction on the return line to the tank, or the FPR was damaged.
