Can't get bank 2 camshafts / sprockets to sit right
Discuss topics related to the VQ series engine.
Benzito82
Car: 2004 Nissan Murano
Yes, I am a rookie, so be gentle, but I didn't put my motor on top dead center like a dumb a** and now I have bank 1 lined up and the rest of the timing chain components but bank 2 just will not line up. I need help because I have the sickest feeling that my cams are bent, or maybe even worse. And by the way, the little nipple on the big sprocket broke as well.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If you tried to turn the crank with the chains off, there's a pretty good possibility that a piston is ramming a valve and preventing one or more of the cams from moving. You need to turn all four cams in the same direction as you turned the crank until you reach a point where everything will line up again. It's a PITA, you open a giant can of worms when you pull the chains on an interference motor without lining up on #1 TDC first.
Benzito82
Thanks appreciate the reply and so at this point I have the chain back on it and hitting all the marks got it turning pretty smoothly and I think I have everything lined up tdc.. both of the little pins broke on my sprocket so I had to modify them. I'm not sure how that's going to go so I drilled out where the pins broke off on the sprockets and drove a little small nails and then put washers behind the nail heads this will not be long-term, but just temporary until I get to go back to the junkyard I just want to see if it will start. Do you know what degrees are for the cams? Also, how do I match the cam caps?
VStar650CL
Technical Expert
Dunno what you mean by degrees, but you can get the camshaft diameter and runout specs on EM-139 here:
https://www.nicoclub.com/service-manual ... 4%2Fem.pdf
To my knowledge, Nissan doesn't publish lift and duration specs for any of their cams.
The #1 cam bearing cap is different from the other three. The cam journals are precision-machined and bearingless, if oil clearance exceeds the spec (about 0.006" across the board) or the inner/outer journal diameters are out of spec, then you replace the cam, head, or both as necessary.
Return to “VQ30DE / VQ35DE / VQ35HR Forum”
