Can't get above 3000 rpm
tfitzs01
Car: 1990 Infiniti Q45
Put the 90 Q back together. And running into big issues. I think the iac valve is chirping. But might be a vacuum leak too in the same area since I can get an rpm change when I spray some Carb cleaner in the vicinity. All hoses are connected.
And all hoses are new. Plenum gaskets are new.
Also when I went for a test drive .... it will not go above 3000 rpm. When I floor it, the cars rpm will bounce between 2700 and 3000. Think that the car is in limp mode after changing all the harnesses in the bay.
Ideas?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Crank Angle Sensor.
tfitzs01
I see that it is the crank angel sensor based upon the ECU code 11.
Anyone know where I should be looking in the engine bay?
tfitzs01
Well I am an idiot.... Located on the Drivers side front of the engine, in directly below the MAF...
I cleaned the pins, bent them in slightly to really get a good connection, added dielectric grease. Been 20 minutes and no codes thrown so far.
Hopefully this fixes it.
