SGGilmo »
https://forums.nicoclub.com/sggilmo-u266914.html
Mon Aug 08, 2016 12:56 pm
Ok first off. Hi. Yep I'm new here but not new to the auto scene. Anyway....
I'm getting ready to do a 5speed swap into a 95 240 and I have read every swap file I can find but for some reason with hours of searching and reading I can't seem to find a reason why no one uses the factory harness. when I do my swaps I like them to be as clean and factory as possible. I will be using a manual transmission ecm and would like to use everything that would have came from the factory.
that being said can I use the factory 5 speed harness and ecm and literally wire this up like it came from the factory this way? I don't care if it takes more time or money or whatever. just would rather have everything look stock. thanks in advance for your input.
