can't find tie rod bushing replacment tutorial
Graphfixz
Car: Black 91 240SX Hatch
anybody know where I can find this tutorial? I have searched and searched and can't seem to find or remember where I saw it.
I need to replace my bushings!!!
Thanks!
Dookie
Car: 1993 240sx Coupe
Tie rod bushing? Do you mean steering rack bushings or tension rod bushings?
Graphfixz
yes, sorry, it is tension rod bushings.
ricebike
2002 Quest
2005 Altima
using polyurethane bushings? read this:
http://dimequarterly.tierranet....html
from what i can recall, http://www.importfanatix.com had a good writeup on the install/tech section, but i can't find it right now.
I'm guessing that u know the hardest part of the job is to press the bushings out of the rods.
zerothread?id=68682
you basically haveta torque the bolts down to spec while the car is on the ground. no trip to the alignment shop if u do this, unless u got 1 of those "adjustable tc rods" w/ the solid joints.
