goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Mon May 18, 2009 12:50 pm
Pick-n-Pull. I don't believe anyone makes aftermarket strut mounts. Depending on your standards and how much $$ you have, if your talking about the rubber pad the spring end rests in it's probably OK to reuse the ones you have unless the spring tip has worn through the rubber and is contacting the metal cup. My opinion only- Member standards vary.
