Can't find a window molding for the rear doors!
tico1965
Car: Infiniti I30, Qx4
What the heck, I understand that this item is dealer only. Also most of the Pathfinders and QX4's have the same problem as mine, they rust out.
Does anyone know where I can get a aftermarket or cheap replacement? Even the junk yards won't give them up un less you by the whole door.
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
i bought mine from courtesyparts.com it was very costly with brokerage fees to come here in canada. All 4 cost me close to $600 shipped. still cheaper than dealer and no eyesore. The WORST spot is under the mirrors..
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
I did the same thing as QXXX4. Ordered them from courtesy parts.
There are no aftermarket or cheap replacement parts available.
You have to go OEM. Sorry.
I didn't ship to Canada though (I live in Ottawa, Ontario).
I had them sent to a friend in Virginia, and picked them up there while on vacation.
They were still over $100.00 each though.
tico1965
isn't that crzy, I can't understand why someone hasn't tapped into that market... they always go bad.
RyanEvh
Car: 2001 Nissan Pathfiner
Maybe try a junkyard/wrecking yard. My friend went to one in Florida and bought two for the rear windows in perfect condition for $10.
Qxxx4
2012 Ford Mustang
I really wouldnt recommend that, the stripping is basically strips of easily bendable metal coated in rubber. They pretty much clamp on and when you remove it you ave to bend the metal to get the damn things off. Even if you take them from a used vehicle they may look fine but under the mirrors of the front door it will be all rotten. The weatherstripping actually goes all along under the mirror.
I cant find my post from when I did mine so here are some photos of what mine looked like last year. the edges of the new stripping had exposed metal so no wonder they get so damn rotten. i ended up putting a slab of black RTV on each end, shot in the dark to help extend their life. Notice all the RUST. I couldnt see any of it, only small bubbles, no brown. But once I took them off they basically fell apart and broke apart and all the rust was exposed. ESPECIALLY under the mirrors. I really dont recommend buying used ones. Sure their expensive, but you really dont want loose fitting stripping or else water will collect under the stripping and get inside the window area, really not a good idea.
THIS is why I replaced them, this was the worst spot, but notice in the pictures that follow how bad things really were..
heres the new stripping, this is the area that goes under the mirror, i put black rtv on it
I originally wanted to replace only the back 2, but i figured with same price shipping if I got all 4, i did so, and believe me Im glad i did. Hope this helps you guys out :chuckle:
Buzzman
Qxxx4 wrote:I really wouldn't recommend that, the stripping is basically strips of easily bendable metal coated in rubber. They pretty much clamp on and when you remove it you ave to bend the metal to get the damn things off. Even if you take them from a used vehicle they may look fine but under the mirrors of the front door it will be all rotten. The weatherstripping actually goes all along under the mirror.
I really don't recommend buying used ones. Sure their expensive, but you really don't want loose fitting stripping or else water will collect under the stripping and get inside the window area, really not a good idea.
Having replace all four of mine, I totally back you up on this one QXXX4.
Even if the used ones are in perfect shape on the donor vehicle, you will ruin them just taking them off.
It's impossible to get them off without bending or damaging them in some way.
They seem to be a one time use only item. Go new.
slickroger
Car: 2001 Nissan Pathfinder
Even if the used ones are in perfect shape on the donor vehicle, you will ruin them just taking them off. It's impossible to get them off without bending or damaging them in some way.
I have done this twice now and I have to say it was much easier to do the second time. For the back windows if you take the little rear glass it makes it much easier to take out the backs without bending and for the fronts loosen the mirrors and you should be fine.
I bought four from a mechanic in the states for about 100 a piece and I agree with go new you'll get longer life out of them
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
Anyone have part numbers?? Rust bubbles are driving me crazy-price sounds absolutely insane for little pieces of junk...
Edit
Looks like Nissan part number 82830 for rear passenger window at the low low price of $93.66... What a Joke
GRNMACHINE
Just replaced the rear passenger window side. $78 thanks to McKinney Nissan!!!
WWW.FACTORYNISSANPARTS.COM
phone 1-866-742-0297
And just like Brian said above, there is No Way I could remove these pieces without damaging them. And mine too basically broke apart when I removed it from rust. Nice pics by the way Brian.
Appreciate info. Will throw some black rtv on the ends before installing new one this weekend.
Qxxx4
2012 Ford Mustang
Its been almost 2 years and the mouldings I bought are still brand new :) You will notice a difference at first in the shiny-ness between the new moulding and the trim around the window but after a few washes and sitting in the sun they start to match better.
GRNMACHINE
Not much of a difference in the colors/shiny-ness actually. Pathfinder has spent most of its life in the garage. May have to spring for the other side now. Still insane how expensive they are (even at a discount).
