Can't Figure out were the speedo plugs in
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
Can anyone tell me were the stock speedo off of the transmission plugs in on a s13
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
On the manual transmission, I believe it is on the pass. side. You'll also see several sensors that each have a two wire connector and a hex body that screw into the trans., those are the gear sensors for 3rd, 4th, and 5th. The speed sensor can be unplugged (if that's what you are after) by disconnecting that inline fuse looking connector. It is held just off the pass. side of the trans. by a little hook like mount.
Don't know about the auto. trans.
240+civic=pimp
Do you know the color of the wires on the the plug that it goes into?
I am trying to hook my speedo up on my rb20 and forgot where it plugs i on the lower KA harness
Thanksadam
niznos
I know it is Yellow/green by the time it gets to the ECU on 89-92, but don't know if it is that color before any harnesses. Also, the color is not guarenteed to be the same on individual cars after any harnesses.
I bought new gear sensors a few months back and the color of wire before the harness was different.
Hope I've helped in some way.
