yodawill2000 »
https://forums.nicoclub.com/yodawill2000-u27169.html
Tue Sep 28, 2010 7:07 pm
Found it !!
Difficulty : EASY!
Time : 30mins give or take if done properly.
Tools : Quarter inch socket with a 7mm socket / Allen key
New Springs, come as a pack of 2.
First off you need to remove the timing belt covers, using an Allen key.
To remove the driver's one you need to remove the water inlet pipe that goes to the block (the bottom one) also secured by Allen bolts.
It hides 2 bolts behind the pipe that secure the timing belt cover on.
You then need to remove the metal plates over the intake cam gears, held in by 4 7mm bolts.
The plate is under pressure from the spring, so as you back the bolts off get some one to hold the plate down as you unscrew them, that way the bolts won't go flying out and get lost in your engine bay.
Once you get them lose just undo them by hand just so you don't drop them.
There will be a bit of oil in there, nothing to worry about.
Next insert the new spring into its home,
Next go get your helper, and put the plate over the back of the spring, making sure not to pinch the O ring seal with the spring.
Line up the holes on the plate with the ones on the gear and then get some one to push it down, while you put the screws in.
I did them up in a diagonal pattern to keep the tension even all round, didn't want there to be a chance the spring could bend to one side etc...
There you go.. done !
