Logan76 »
https://forums.nicoclub.com/logan76-u38992.html
Thu Oct 02, 2008 5:47 am
HG is a quick referance to HeadGasket. Umm I would buy some electrical contact cleaner and spray the MAF with it see if its really dirty, if not you can check with a voltmeter and see how many volts your maf is sending to your ecu, You can do this by connecting a voltmeter to the signal wire (usually have 3 main wires: power, ground, Signal to ECU) and blowing air into your maf, but older Miatas have a VAF (Vane Airflow Meter) And I know there is 2 types, they both recieve battery voltage but one returns more voltage (older one) to the ECU and one returns less voltage (newer one). I cant really help you on testing your VAF, sorry. When I said Timing I meant your Ignition Timing not your physical timing. Oh and your plugs get gapped at .044.
