GotBoost4Yall »
https://forums.nicoclub.com/gotboost4yall-u5405.html
Sat May 29, 2004 6:38 am
Ok, shes running even better than before.
Went to the local junkyard, didn't get my 944 fans but got a pair from a 1g Eclipse and just a little trimming here and there and mounted them, they work very nice. Car actually stays a notch below normal. I took it for a pretty long test drive too. Not sure if it also helped but I removed the FMIC (piping was never done so I just have it off until i take it to a shop).
Installed a 90 300zx Turbo fuel filter,Denso spark plugs. Autozone or Discount don't carry the NGK!!! While changing the plugs I noticed that a little ground wire on the coil pack harness had been off, screwed it right back in.
Car pulls alot better and feels good.
Also while I was at the junkyard I found an 87 Pulsar NX, but it was a 1.6 ,not the 1.8. I took the ignitor chip and a couple other stuff, will anything from it work on the CA18DET? Just inCAse anyone needs something on here.
No damn boost leaks ok!!!!!!!!
