You didn't mention what you'd be using your car for.. so I'll assume it's for the street... If that's the case, I'd go with a T03/T04E 50 trim compressor, 0.48AR , or if you want slightly more power without too much lag compromise, do a T03/T04 ball bearing with a 0.64AR.
The two turbos are completely different in terms of setup. You will need to fab quite a few parts with the T03/T04 setup whereas with the S15 turbo there are (supposedly) maniifolds that position the turbo so you can use SR20 elbows & downpipe.
Neejay wrote:Let me first say that I already have a 52 trim T3/T04E .68 - it's rebuilt and hasn't been used since the rebuilding. I only want 250whp.
S15 T28pros: can use SR dump pipe, SR SMIC setup to get going, faster spool (?), built in wastegatecons: coolant lines needed, would have to purchase ($800), needs intake inlet + compressor inlet hoses ($100), manifold + dump pipe quality can potentially be questionable
T3/T04Epros: already have, more potential, no intake/compressor inlets needed, JGS kit comes with everything needed + qualitycons: I'd have to get a JGS kit + needed wastegate ($900+), would need to get FMIC setup ($300 + cutting + new battery and/or customizing)
I'd be running whatever PSI would be safe for about 250whp, safely depending on what PSI was needed on the specific turbo.
I don't have a garage, or really any friends to help (hence the JGS kit being needed for the T3). With all that being said, opinions?
