WDRacing wrote:To clock the center section you need to loosen the bolts that are holding the exhaust housing AND the compressor housing. Unless you're just moving the compressor that is. You might need to "break" it free, I use a hammer and a rag for a slight percussion adjustment
WD
WD, You were just the person I was hoping would respond, (hence why I chose the KA-T forum for help on my SR's turbo) and I do appreciate it. I now have it mimicking stock perfectly. I ended up using a towel and a hammer to break it free.. That thing was TIGHT.
