livenlarge wrote:Bro's....be sure to know the question before you post, I have had 6 awd cars sport sedans that were awd, yes, you can stagger tire wdth and rim width but you cannot have any tires that have dif diameter size front to rear, I have 255/35/19 on front and 285/35/19 on rear but rims are all 19x9 on my m35x no prob, I had 40's on rear and still had no issues. I think this is what bro was asking, look at Audi's they stagger from factory on the s-line but width not tire diameter. I hope this helps. Bro's don't take me wrong...I'm new to this forum but not new to cars..but I'm hoping to learn more and meet new people here...
LL....
Don't take this the wrong way:
I hate calling out people (as I'm generally a nice guy and here to help everyone - reason why I made the FAQ thread) but you are so off that it isn't even funny.
Changing the rolling diameter of the four corners separately on an AWD model M is NOT ADVISED and will only hurt your AWD system. In order for the AWD system to work at it's 100% designed specifications, ALL the corners need to match/have the same rolling diameter.
You can stagger, but you better be damn good at math/calculations to make sure all four corners 'seem' the same to the sensors otherwise the system will go nuts. This means finding a combination of front wheels/tires and rear/wheels tires (that are different) yet have the same rolling diameter. Good luck.
Having 255 in the front and 285 in the back on an AWD system is beyond wrong. Especially when you don't make up the difference in sidewall, etc. Your rolling diameter is WAY out of whack with that setup.
I'm surprised your AWD light isn't blinking like crazy.
Please, search this topic and stop spreading poor information to new users who will only come back with numerous threads like, "Why is my AWD system going nuts!?"
Bottom line: Can you? Sure. Should you? HELL TO THE NO.
itsOmar wrote:I'VE ALSO SEEN THIS GEN M CLASS WITH A NEWER GEN FRONT BUMPER. CAN THAT BE DONE WITH NO EXTENDED MODIFICATIONS?
As a new user, please use the FAQ thread that is stickied in my signature or in the main thread area. The HowTo for the bumper swap is written up with part numbers, etc.
Thanks.
