Can SR20DET take 50 shot of Nitrious....
Silvia007
Car: 93 Nissan 240SX SE Fastback
Yeah... can it take 50 shot of Nitrious ontop of 15lbs of boost? And one more thing, whats the redline of a S13 redtop?? Thanks guys.
SpeedRacer1
Car: 1990 240SX, G35
If you have it at 15psi im assuming you have a fmic and upgraded fuel system too. I personally wouldnt run a 50 shot at 15psi but it could probably take it. The redline is 7500rpms.
Silvia007
Thanks, I was just making sure to see what the redline was. As for the Nitrious, reason is because I have the NOS kit around collecting dust in the closet so if the motor could take it then I was gonna do that but I guess not. Hey thanks for replying.
I H8 UR DSM
yes, as long as it is tuned right...and you dont have any detonation...run high octane gas, and larger injectors would be nice....as long as you have a large intercoler, and good fuel, you will be fine...just make sure your car is tuned properly.
jesse
