95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sun Mar 04, 2007 9:00 am
i'm can only guess, but when the car was broken into, did they jerk the wiring out??, if they did, then it might be that the wire batch that is going to the Radio/climate control/lighter could have gotten in contact with ground...... in other words, when they pulled out the radio, the wires might have been pinched against metal causing the wires to be stripped, and touching the body of the car or each other... i would start there.... and make sure that the new wires that you connected are soldered and that are not touching.....
