Can someone with FS identify PN# of this Passenger Side Power Steering hose?
chinaonnitrous
Car: 2002 Maxima to 2004 Evoloution to 1992 Integra
So Ive checked out where the leak was comming from , its a volcano gusher, its on the passenger side, shown here.
It only spew's at full lock. Ive remdied by using an old bicycle inner tube, cut, and 3 hose clamps holding it in place. It now just slightly drips, instead of flooding the driveway.
The hose goes toward the back of the car, across the motor, to the drivers side to this bracket
I dont have a FSM of an older Q, I have hte one for the 1994, I shall dig through it tommrow. If anyone has this PN# handy id be nice. =)
Other than that, Jesda's former Q has reccived a fresh helping of Mobil 1 for thanksgiving
chinaonnitrous
Doing more reading, Ive found that Theres the Main power steering hose, which is Pressure.
This must be the Return one, which is cheaper.....
I found this on Everythinginfinity.com
P/S HOSE, Q45, w/o Active Suspension, Return - POWER, 2 WHEEL STEERING 90-94 $65.23 $48.92Parts And Prices Are For Estimating Purposes Only. Order By Description.
Guru's, am I correct?
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
If you give me your VIN, I think my "FAST" program can identify the part. It is the same program that the dealership parts department uses (don't tell anybody I have it).
Q451990
I think there are actually three hoses that are considered high pressure. I replaced mine that had a leak in the exact same place - and I don't think it was that cheap... I lucked out and found one in a salvage yard.
Here's another option for you. zerothread?id=4470
If you're ordering one from Infiniti of Scottsdale - they are very good at identifying those hoses... I think they sell a lot of them.
Heath
chinaonnitrous
Heath I definatly saw that post, the hose looks great, except, I work EVERY DAY untill mid Febuary, As i work 2 retail jobs.
I wont have time to remove/drive around, get service, and put it back. I might call around to see whats going on with the hydro shops around here. Id rather just remove/replace.
BUT!, the triple hose clamp + rubber insert, seems to have slowed down the leak ALOT, so I may just ride it out, untill I have more time. I guess it depends on the price of the hose.
Mr. Jeff Im going to E-mail you. Yes that nissan FAST is an awesome tool. Ive used it at a friends....house....
Q451990
The shop in Columbia had same day service... some folks in AZ indicated it was a "while you wait" thing there... so if you have an extra vehicle you might be able to pull it off...
Heath
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
I entered your VIn and here is the PS hose drawing. I colored the lines to help determine the part number.
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
This appears to be all the hoses with descriptions.
I think, by your picture, it is part number 49722M
mattd1979
Car: 1990 Pearl White Q45 plain Jane with 266,000 miles. 2015 moonlight white metallic Q70L with 20” wheels, sport brakes and a 5.6L at 58,000 miles.
I bought the hose that you are speaking of becuase mine did the same thing. The part number is 49720-60U1. It is a steel line that has a hose on one end and the other is a junction block that mounts to the frame with two screws. Hope it helps.
Ive always wondered about that damn leak. Good to know the rack is okay! Now you can replace those boots.
chinaonnitrous
Boots?!?!?!?....they looked fine..... nuts... Theyre torn huh?!. I'll do them when I do the SPL upper links and SPL Tie Rods. One step at a time. .... Pay day is surre a long way away.
Thanks guys, THe nissan FASt and the part number is a big help. I'll be contacting Infinity soon. =)
drftard
Car: 1992 Inifini Q45/ Nissan G50 President
jeSUS!!! this is MY CARRR!! OMG!
96Qowner
Car: 1996 Q45
Nice to see that Jesda's Q45 has remained in NICO members' hands.
drftard
unfortunate that now the ps pump is now out so back around the same area i presume....
