DriftSpecial180 wrote:Thats what i've having trouble with. If its a CA harness+ECU why do you use KA plugs? I work on my S13 all the time and have done mechanical work. But i've never done Electrical work. I'm not scared to swap the motor just worried about wiring.
To quote from Heavy Throttle; There are 2 plugs on the end of the KA harness and 3 plugs on the SR[CA] harness that run up behind the stock battery location. Although the plugs do initially snap together, the wires do not line up and you have to cut the plugs off and connect the wires using the table below. Cut the 2 main KA plugs off the KA harness and splice them onto the SR[CA] harness. Not to be a jerk, I don't understand what is confusing about that. If it is confusing I'll draw you up something on paint. Just lemme know.
You can run into some problems if you didn't/don't get a lower harness with your motorset. If you've got to use the KA lower harness things get a little more complicated. Not horribly, but if at all possible, use a CA lower harness.
The last thing is that if your car originally have a SOHC KA in it, there is no wiring for the knock sensor in the chassis or the lower harness. You'll have to find a plug for the knock sensor and run the wire directly into the engine harness. It will have to be sheilded.
