QE86 wrote:As I have said, there was ABSOLUTELY NO SMOKE whatsoever just some weird sound when i try to start the car....
Alright, was it by any chance raining hard and you ran through a huge puddle of water ? Hydrolocking the motor and throwing a rod....
I doubt the head gasket POPED all the sudden that sever to dump lots of coolant right into the cylinder and hyrolocking the engine.
My Q45 had 2 blown head gaskets, but the problem was that the person before me overheated the motor a few times and warped the heads really bad. I had the machine shop check them out and I was told they where junk- but they could fix them for extra 200 dollars. They torqued them down to a big metal plate and stuck them in the oven to heat them up- this flattens down a warped head CONSIDEREABLY. After that they milled the head bout 2 thousands of an inch to make it perfectly flat. My engine would eat coolant at a fairly good rate, and at the same time it would pressurize the cooling system to the point that the radiator that the previous owner had installed- burst. I would have to add bout a gallon of coolant a week in order to keep it runing OK. At the same time engine would missfire and run rough due to coolant getting into the cylinder.
I didn't want to buy a unknown condition JDM motor, or spend even more money on a US motor, so I rebuilt mine. I still don't have it runing as the header project is getting in the way. I have to put the intake manifold on along with all the new hoses under it, install the exhaust manifolds, belts and fire her up for the 1st time in almost 5 months. It should be a beast
Good luck on your Q.
