Can someone tell me if this headunit will fit in my versa?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
sisco33
http://www.onlinecarstereo.com...17408
I cant seem to find the dimensions. I have a 2007 Versa S Hatch.
CodeRed
Car: 2008 Nissan Versa S MT
Yes, the versa holds both single, and double din headunits.
BlueMango
Car: 2008 Nissan Versa S Hatchback
Here are the dimensions according to DUAL's owner's manual:
Chassis dimensions: 7.13" x 6.57" x 4" (181 x 167 x 101 mm) Faceplate dimensions: 6.85" x .67" x 3.85" (174 x 17 x 97.5 mm)
danoops
Car: 2007 Nissan Versa 1.8SL Hatchback
It will fit. In the listing it says DIN: 2 which means it should be standard double DIN opening.
Return to “Versa Technical Discussions”
