Chaotic_Warlord »
https://forums.nicoclub.com/chaotic-warlord-u26051.html
Mon Dec 05, 2005 5:15 pm
Ok I just replaced my water pump and fan clutch on my 95 240, did it all like I was supposed to even gave the waterpump gasket sealer a full 36 hours to cure before I started the car up, wanted to make sure it wouldn't leak. So I let the engine warm up then went for a drive about 3 miles later I was really really overheating, so I turned around and shut off the car for five minutes or so, checked my fluids and topped off the radiator, let it idle for about 30 mins and putting it under load a couple of times by revving and holding it at aroundd 2500 rpms for a minute or 2 and it stayed at the normal operating temperature. So I figured it was fine, left to go again and by the time I reached the same 3 mile point I was already overheating at maximum, or so my gauge said (arrow pointing straight up) since i was already late for work i figured I'd limp it along and see what it would do, by the time I got a couple miles down the road it was starting to cool off, and by the time I got to work about 10 miles from home it was back holding steady at normal operating temp. Now it's doing this, it over heats (just reaches just under the H mark ) stays that way about 2 miles and then rapidly drops back and holds the normal mark. Now I plan to replace the thermostat and see if that helps but could there be somethign wrong with my gauge? I mean it says its overheating but when I turn the heat on all it does is blows cold air and then when the gauge goes back to normal I get nice warm air (which right now in Philly is a good thing) . I understand the risk of running an overheating car and know Im risking my head gasket and damage internally, but I really don't know that the car is overheating. Could I have somehow bumped the temp sensor and made it off or is there air somewhere in my cooling system. Also when I squeeze the top hose at normal operating temp its not hot and there is no surging feel to it. but the car runs fine, no noticeable knock or fuel consumption I don't have any new oil leaks. I'm so confused, but like I said I plan to replace the thermostat, and I take it in wed to have the EGR solenoid replaced so I was planning on having them do a full cooling system check and flush while they're at it. Any help would be much appreciated.
