Can someone pleeease help me
antz
Car: nissan bluebird TR-X u12 and nissan bluebird SSS u14
Ive just hooked up the t3 skyline turbo i purchased. The oil feed line is tee'd in with the oil pressure sender, Oil outlet is piped to the sump plug (temporary). On start up it blew a cloud of blue smoke and oil started dripping out of turbing outlet flange (piece that joins the turbo to the exhaust system). When i reved it more oil came out and a WHOLE lot more white/blue smoke .
what would be causing it to do this?Should i get it swapped or a refund?Have i connected it incorrectly?
Any insight would be awesome.
S13ChucKAT
Car: asd
Excessive shaft play, your turbo is blown, and needs a rebuild
WDRacing
If your turbo is dumping oil out of the exhaust housing that bad your seals are non existent. Get a refund...
Willfastbackse
Car: Cars, girls, movies, basketball
Turbo Oil seals blown for sure.
antz
Thanks guys for the advice i am hopefully getting a replacement today.At least now i know how to spot a blown turbo. Thanks again for the help
