MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Fri Oct 04, 2002 8:51 am
It's a good idea on paper, but I don't know how you'd make the "ram air" out of aluminum, or where you'd connect it in the front of the car (unless you moved your battery to the trunk and dropped the extension down in the bumper like a regular cold air intake. I don't know what kind of tubing you'd use either, I'm guessing just like cooling duct stuff, which is convuluted and not that good for flowing air, but much better than nothing. Connectind directly to the ITB would be much better than just connecting somewhere around the ITB and letting its cold air out there...because the cold air would quickly mix with the hotter air or be swept away (esp at high speeds.) BUT, I don't know how you'd connect it to that big air filter that'd be right near the ITB, because if there are 4 individual throttle bodies, it would be a huge, oval shape air filter...you'd need some type of fan thing that would cover the whole air filter, and then I don't know how well the air would flow or how good it would be to rely completely on this "ram air system." However, I'm sure it could be done...
