Can someone please explain this 1/4 time?
absolum
After many month of problem solving I finally took the car the track, I could not do many passes because I somehow blew my rear transmission seal after the 1st run.
R/T .62960' 2.5841/8 10.065MPH 76.931/4 15.016MPH 100.23
I am running s13 sr20det with t3/t4 turbo at 8 psi, I still havent really figured out how to lunch the car yet ( .64 exhaust housing is laggy) and there is room for improvement as soon as i get my injectors.Question: Can this car do a better 1/4 time if I keep practicing or is the car too slow to do any better?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
keep practicing and tune it. what else is part of your setup?
jr_ss
Car: 95' S14
You have a fairly high trap speed, this should be a 13 sec car. Get your injectors, get a tune and go back to the strip. Launching the car is all a learning lesson, no two cars will be the same, unless it's an automatic...
audtatious
Your first 1/8th is killing your times.
absolum
Thank you guysthat is exactly what I needed to know.
I will be doing some practice this weekend,
Would you guys know what will be a average? i would assume under 10 seconds LOL
BTW: JDM_master_X , my setup is s13 sr20det
- 57 trim t3/t4- 38 ml external wastegate , - Customer tubular manifold- GReddy copy intake manifold- 3 puck clutch with spec pressure plate. - 3 inch exhaust with cat- Z32 maf- 8 psiEverything else is stock on the car including the injectors.
jr_ss
Car: 95' S14
You really need new injectors and a tune to take this car to it's full potential. You're choking it or suffocating it rather, with the lack of fuel.
I ran the same trap speed as you and clocked a 14.3 on a BPU S14 SR @ 10psi...
GTS4-R
Car: my feet
2.5 60' ft????? work on that LOL....a t3 t4 sr should be high 12's easy...up the boost...8psi is way below the turbo's effecientcy.....run 21psi and pull mid 11's
Eikon
Car: 71 240z, 93 Supra TT
93Niss240 wrote:2.5 60' ft????? work on that LOL....a t3 t4 sr should be high 12's easy...up the boost...8psi is way below the turbo's effecientcy.....run 21psi and pull mid 11's
Make sure you get new injectors and a tune before you up the boost!
GTS4-R
Car: my feet
holy **** ur running on stock inj??!!! ever play with matches covered in gasoline????....... well you are!
