tmorgan4 »
https://forums.nicoclub.com/tmorgan4-u52698.html
Wed May 26, 2010 11:37 am
Thank you doing this David. Just to be clear, did you measure the part of the crank that protrudes from the timing cover? The measurements seem correct if they are 1.XXXX". Just want to make sure!
It's up to me what size pulley (how many teeth) get put on the damper. I've been looking through the available dry sump drive pulleys, to make sure that I end up somewhere in the middle and have adjustment for faster or slower pump speeds. I've mainly been looking at Peterson since they're somewhat local and they make nice stuff.
They have dry sump drive pulleys available in 32-49 tooth counts (with not every size being available in between). Their crank drive pulleys are available in 18-33 tooth counts just for reference. I think I will have a 20 tooth put on the ATI.
This way I can buy a 40 tooth dry sump drive (it's available) and have my 50% of engine speed. I can go up or down from here if need be.
I do think that would be nice to have the HTD drive on the front, but it's all a big compromise. Putting the HTD drive on the front will either mean A) relocate all the accessories (alternator, power steering, water pump) to move them close to the timing case OR B) Have a longer assembly with the accessories mounted in the factory position and the HTD drive hanging off the front.
I don't think it's going to be a big deal to loosen the single serpentine belt to remove the dry sump belt whenever I need to. I'm not racing this car so being able to quickly prep the car isn't as big of a deal (although it would still be nice). The only reason I should be pulling the HTD belt off is for maintenance (which should be done fairly regularly...if it breaks I'm screwed), or to change the size of the drive. Neither one is all that often that I'm worried about putting the HTD belt behind the serpentine.
I do appreciate the criticism. It makes me double check my thinking. It sucks when you get an expensive part and wish you'd have done something different.
