evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Nov 05, 2012 8:34 am
I'm sorry but you'll need to be more specific, the S30 uses 2 different hubs, the 240z and the 280z have different thickness's. Their tital offset to the disk is the same but as the disk hub was offset to compensate, and the s130 is a completely different animal. The TC rod on the S130 comes to the front of the car and the S30 goes towards the rear. I assume this is what you meant when asking about the lca as the disk is closer to the tc rod when turning but no the lca.
