can someone help me who has change there grill on a coupe
ryan_g35
Car: Infiniti G35 silver blacked out =]
hey i ordered billet grill set and black side markers last night .but tonight i was waiting on a pizza to get to my house and i was looking at how to take out the grill. wel is there like a latch or something on the side cause i took out all the screws and i coulded get it out lol
help plz
johnparkyourcar
Car: 03 DG coupe 5AT
theres 2 more screws other than the top part. towards the ends look thru the grill and there are screws on either sides. i think ive seen directions with pictures on another forum before
infinititech1
after you take out the clips from the top it pretty much pulls hard...some of them are pretty hard to get out
ryan_g35
oh so its just really hard to pull outwell it makes sense cuz i could not see any more clips.
hey question how hard would it be to put the factory navigation into the car if i didnt buy it stock?
champagneG35
Car: '03 Champagne G35 Coupe 6MT Brembo (sold July 2015), '73 Datsun 240Z,
What Year Coupe ??
I just took mine out the other day when I installed my CAI cause I thought I needed to remove the whole front bumper.
It's farely easy, I wouldn't simply pull hard though! you're likely to break the lower clips and 2 side upper clips that way and render the stock grille and possible mount points for the billite grille useless.
Here's a quick removal procedure:1) Use a flat tip screwdriver to lift up the center portion of the top hold down clips, then remove the clips and set them aside.
2) Reach your arm down the inside of the grille (the side closest to the engine). Starting a few inches from the edge you will see and feel tabs sticking through holding the bottom of the grille in place. bend these downward slightly one by one while pushing them outward toward the front of the car, don't worry if they kinda semi go back in when no pressure is applied they wont click in and if one does you'll hear it.
3) Next on the upper corners of the grille you'll find 2 more clips work one side at a time and push the clips off towards the the outside of the car while pushing to the front of the vehicle. Once one of these clear the second is way easier cause you can then open the grille kinda like a door until the other side slips out.
Just remember it's plastic and can break easy so don't rush it
Here's a pic from the service manual which should help. This is for a 2003 Coupe though may be slightly different for your year if it's not an '03
Modified by champagneG35 at 1:04 AM 1/1/2008
ryan_g35
thank you very much that diagram helps
but i did every but the side ones next to the lights
