Lt.Mike »
https://forums.nicoclub.com/lt-mike-u20681.html
Sat Apr 02, 2005 7:31 pm
What he means is that you take your hard linefrom your clutch master cylinder, and screw it into your clutch line hose. This will require youto bend your hard line 180 degrees, but it can be done*.
What this will do is give your clutch pedal a firmer feel giving more control over your clutch.This also makes bleeding your clutch sytemnot an all day affair (unless you have a speedbleeder on).
*There is a risk in this that in which you can strip nuts, threads, break line, etc. I did it and a whole bunch of 240 owners as well.
Hope this explains it.
