can someone help me identify what year this is? 56k go make a cup of coffee
adrianfromthecastle
Car: 1992 Nissan 240sx
i got these q45 calipers but the guy i got it off of didnt know the year it came from...so i was hoping the gurus would know
also... how do i know which side is driverside and which is passenger?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
They look like 90-96. is there a part number anywhere????
IM not sure, but the 90-01 calipers are the same... the only difference that im aware of is the caliper bracket is different to accomodate the 296 dia rotor vs 280 dia rotor.... I think the calipers were the same, could be wrong though...
for drivers and passengers, theres a L and R on the calipre . For your reference, the bleeder has to be facing UP otherwise they wont bleed right.... shows clearly in the second pic.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Wes is right those are definitely 90-96 (i have both 94 and 97).those will look good painted up nice. since someone already started stripping off the crud.....I use jasco metal etch to prep the surface for max paint adhesion.
adrianfromthecastle
thanks elwesso... your the man.
GQ Jay wrote:Wes is right those are definitely 90-96 (i have both 94 and 97).those will look good painted up nice. since someone already started stripping off the crud.....I use jasco metal etch to prep the surface for max paint adhesion.
thanks man, i'll take your advice... any other tips?
elwesso
2007 BMW M Coupe
Jay, are the calipers themselves on Y33 vs G50 the same, and the only difference being the caliper bracket being farther apart for larger rotor? Or are the caliper bodies and the pads different too?
How can you tell between Y33 and G50 brakes??
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
Wes i maintain that even the calipers are slightly different. they *may* interchange, i haven't tried.look at this thread (4th picture from top), the fy33 caliper has shorter venting slots.
zerothread?id=107345
of course, you are correct that the brackets are different. for one thing, the 90-96 have pin snubbers, and 97-01 do not. i actually can't tell from this post's photos about the snubbers, i just assessed based on the vent holes and overall caliper 'look'.
you know the rears are same, mounting holes and all EXCEPT for the vented rotor and corresponding caliper and bracket being thicker.
elwesso
2007 BMW M Coupe
Jay thanks, i made that thread you posted an article....
im sure the calipers would bolt up just the same, like we can put Z32 calipers on Qs....
