Can someone help 300zx tt?
jrnicl3
Car: 1990 300zx 2+2
Please let me know what I am getting into with the following 1993 300ZX TT that I plan to buy and what could be the cost for the fix:
Paddle clutch is way down. I assume the master clutch cylinder needs to be replaced. So I can't really test drive the car.
Steering fluid is leaking. Must be the hose that needs to be replaces.
A cylinder has low compression.
The Interior looks good. Airbag light is on due to radio console removed.
The exterior has a couple of dents''
How much would you pay for the car?
Thanks
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
With all those problems, I'd say 2k MAX. And that's assuming it actually starts/runs/idles good. It's pretty crappy that you can't test drive it though. How much is he/she asking?
EDIT: Now that I think about it, maybe even less since that one cylinder has low compression. Low compression = rebuild = $$$
Shoey2
Car: 1990 300ZX Fairlady Z Twin Turbo
dont buy it...
nissanfreak12
Car: 92 300zx 2+2 TT
Shoey2 wrote:dont buy it...
This^^^^^^^
unless you want a project and have money. You are easily looking at roughly 5k++ just to get to running condition. There could also be a few more issues that you are not aware of.
The airbag light on means there is a fault with the system, not because the radio whatever is out. More than likely the airbag has been deployed, if that is the case, walkaway!!! It is a PITA to deal with a car that has front end damage.
twinturbozxtacy
Car: 91 tt
way to double post.... anyways walk away!
jrnicl3
Car: 1990 300zx 2+2
Sorry for the double post. I needed a fast answer. The car has 82k miles and he wants $3500 for the car.
t.mcginley.jr
1966 Ford Mustang
jrnicl3 wrote:Sorry for the double post. I needed a fast answer. The car has 82k miles and he wants $3500 for the car.
Tell him to take a hike. Just wait and find a better one.
jrnicl3
Car: 1990 300zx 2+2
Awesome! Thanks for all you help. I was closed to make a bad decision.
