SuperHatch wrote:I need to know the distance from the transmission mounting surface of the block to the mounting surface of the crank or flexplate.
Does anyone know for sure that the block/crank distance is the same as a Z32TT?
Both of my VHs are torn down right now or I'd check myself.
Thanks!
This is a pic of my setup. The trans is NA with a TT flywheel and clutch. The trans is flush to the engine and I had to put the factory VH auto trans spacer behind the flywheel to get it to line up, otherwise the flywheel sits closer to the engine. Hope it helps.
