Can someone double check my wiring research (S14SR manual into S14 Auto 240sx)
sean350z
Car: 2003 Nissan 350z
Here is my preliminary chart for wiring the F4 from the S14SR to the S14 Zenki 240 M63http://www.seanjlawrence.com/p...00469
For the transmission wiring....1. Close circuit on the top connector (E15) on the 240sx next to the fuse box2. Using the Auto 240sx reverse light connector (third down next to fuse box) wire it to the reverse light connector on the Manual SR.3. Run speed sensor wires from SR transmission to ECU pin 53 on F1I realize there is a 5th position switch but understand this doesn't need to be hooked up as well as the neutral position switch (b/c i'll be closing the circuit on E15)
The only thing left for me to figure out is the ABS wiring. Obviously I have to take the connectors off my KA engine harness but not sure how or where I'm going to hook that stuff up. The wiring diagrams for the ABS are so confusing....
So seeing the above things...is there anything i'm missing or am I way off?!?Thanks guys.
