ceniack »
https://forums.nicoclub.com/ceniack-u14675.html
Wed Oct 11, 2006 11:53 am
k, i have some pics of my progress so far in hooking up the coolant lines, and i have came accross some i can;t quite figure out. there is is a port that is just above where the oil filter, and then another one that is above and to the left, i also have a hardhose that has two ends of different sizes that looks like is what connectes these two, but where the ports are don't match up
then i have the hardhose on the back, one end i assume goes to the heather core, the other end i do not know, and ten there is the hardhose that has one end with two ports, a larger port and a smaller one, the smaller one i assume goes to the turbo coolant line, the larger one i assume goes to the heater core. if i hook all of these up, i will still have one open port that i can't figure out.
-terry
*edit* NM got it all figured out
Modified by ceniack at 9:29 PM 10/11/2006
