can someone describe these symptoms
red_240_fastback
Car: '86 300zx turbo, 1989 240sx fastback, 1990 KA24DE 240sx hatchback
sometimes when you are driving and push the gas the rpms go down and it sounds like it dies but the after holding the gas for a second it goes. sometimes it will actually die and when you try to start it it will just crank and won't turn over and starts to smell like gas. can someone please help me with this?
240sxOwner
Car: 93 240sx
mine was doing that for a while...clean out the TPS and all intake sensors, that worked for me.
DGA
Car: Cars
If it smells like gas it means that the injector O-rings are gone and the gas is rushing past them into the cylinder. Your engine is flooded, and that is why it is hard for it to start, if it starts at all. O-rings are very cheap. Go to the dealership and get some. Make sure you lube them up before you put them in, otherwise they might rip again. Very easy and cheap fix.
red_240_fastback
thanks for your help. it drove fine for a coupole days then it wouldnt start at all. this past weekend i got it stuck in the drive thru at chickfila so right now i have it parked until i can get it running good
chandler
Car: 91 civic hb & 96 S14
fuel pump
chandler
ask mike its the fuel pump
red_240_fastback
thanks
red_240_fastback
im going to try to work on it this weekend
red_240_fastback
i checked the ecu yesterday and it was throwing a 13 which i found was the coolant temperature sensor. does anyone have any information on this? thanks
chandler
unplug the sensor and see if coolant seeps out, then you know its the sensor. other than that, look at the FSM, find the correct test procedure and test it
red_240_fastback
i dont have an fsm so if someone could help me out i would appreciate it. and also where exactly is the coolant temperature sensor?
Nismo_Freak
Car: 89 Nissan 240SX
A faulty coolant temp sensor will make the car run like crap all over the powerband... this is because the ECU uses the coolant temp to determine the coordinate on the fuel and timing maps. What it's doing is dumping fuel into the cylinders because it is throwing an error and going into the default error map.
Replace the coolant temp sensor and I bet your problem goes away... it's cheap and it's easy to replace. If you get an intermittant overheating problem after the install you need to bleed the coolant system of air.
The coolant temp sensor on the DE's is located right by the thermostat housing (the engine end of the upper radiator hose, where it connects there should be two plugs, the larger should be the coolant temp sensor)
On the E's the coolant temp sensor is located on the lower coolant hose where the two lower sections combine. There is a small sensor in a pipe fitting.
Nismo_Freak
chandler wrote:unplug the sensor and see if coolant seeps out, then you know its the sensor. other than that, look at the FSM, find the correct test procedure and test it
No need to test it if the ECU is throwing that specific code... the coolant temp sensor code is a direct code in which the ECU is recieving an abnormally low or high code, or no code at all. Either way the sensor needs to be replaced.
chandler
I didnt know how much the sensolr was, or if it was a wiring fault. ive seen the guy next to me at the shop throw parts at something too many times, and it be a connector or a wiring problem. I know that cryslers are bad about wiring going bad. id rather test it and be sure.
Nismo_Freak
Fortunatly the build quality on the Nissan electrical systems are superior to about 90% of what the domestic companies can come up with and these problems often don't arise withen the wiring.
Wiring also would usually cause an intermittant problem in this case, not one consistant with everyday operation. That is unless there was a total failure of the wiring, which would be easily visable unless it was as far back as the ECU pin-out, but I've never seen that problem on a properly grounded and powered engine harness (ie. someone didn't ghetto wire their engine).
red_240_fastback
thanks for all your help i went and picked up the part this morning at the dealership for $21 and i will change it after school and work. when i get it done i will let you know if it worked
red_240_fastback
so i put that part in this weekend and now it is running very good. thanks everyone for your help
NISTECH
make sure there is no corrosion in that connector for that sensor.
red_240_fastback
alright
