thanks man but it looks like you got a boost controller and your BOV is on the opposite side of mine i wonder if that makes a diffrence??200RX wrote:Check it out fellas, I run a Greddy type RS bov atmospheric. Here's my set up. It bogs sometimes but I think I have a bad bov. But everyone said my set up was good so here it is hope this helps!
alright thats good but but my hot pipe doesnt have a spot for a vacuum line do you have a pic of one?? plz im trying to get my car squared away by saturday( first drift event) hahahduffman1278 wrote:Not sure about the intake because mine doesn't have a spot for a vacuum line but the wastegate is more efficient if it runs off the hot pipe, as close to the turbo as possible. Besides that, looks fine.
That shouldn't be a problem. FRsport sells nipples with tightening hardware. They're $10. They told me to drill a hole in my coupler attached to the hotpipe, then insert the nipple through the inside of the coupler and finally, tighten the bolt from the outside to keep it in place. If you don't see it on their site, try calling. I went to their store today and they had 'em in stock. Hope that helps.Team_Undisputed wrote:
Are you sure thats right? How is your boost controller NOT hooked up to your wastegate? It should be. you should have an OUT line going to your wastegate and an IN line going to your controller. without that I don't know how your system could be working.200RX wrote:Check it out fellas, I run a Greddy type RS bov atmospheric. Here's my set up. It bogs sometimes but I think I have a bad bov. But everyone said my set up was good so here it is hope this helps!
nice set up man, the main reason i want to get that wleded on is because i took my car to get inspected by the SR guru here in town and he took off my boost solenoid and switched up my vacuum lines and ever since then my turbo has been really loud (screechy) laggy it used to kick in at 2700 and now it kicks in until 3500 and ive checked for a leak and i found that it was missing two bolts and i put those on and the screeching got lower but the turbo is still laggy so can this be a wastgate vacuum line problem??200RX wrote:This is a Greddy IC kit my brother got, it came with the bung already in the hot pipe. Try calling some local machine shops and see if you can get one put in.
Here's a close up, I teflon taped it up hardcore. The nipple I got at Home Depot, I'm sure any hardware store would have one.
Nacho_240 also has a sick idea. May cost less his way, good job Nacho
Modified by 200RX at 8:11 AM 9/25/2008
I'm not sure about the situation with the turbo ,but yes you can hook your wastegate to a nipple on your hotpipe. The closer to the turbo you can get the better.Team_Undisputed wrote:
and i was also wondering if i could hook up my wastegate line into my intake line since its close to the turbo and all.
Off the FPR.positron_ wrote:Speaking of boost gauges, where do you run the vac line coming from the boost gauge to in a setup like this?
did you use pipe a pipe thread tap to make the hole?duffman1278 wrote:
Off the FPR.
As for the hose barb, here's what I did, sorry I don't have a pic, never took on but its simple. I just drilled a hole slightly smaller then the threaded part on my hose barb and I ran a tap with the same dimensions as the barb into the piece I drilled. After that I took some JB Weld and put it on the threads of the barb and threaded it in. Allowed it try for a day and it was SOLID. I've had no issues so far. Just go to the hardware store and get a barb that'll fit your vacuum hose nice and tight.
