thanks alot for the info, i havnt gotten a look on what 16's look like so i cant make a good decision on those i see 17s all the time and they seem to fit the wheel well the bestim_looking_for_a_240sx wrote:its latter. buuuttt for less rub and no need for spacers, go with the lowest offset ones. you may bet fender rub, depending on your height with the 0 offset ones.
for s13's i'd say 17's look and fit the best. so go with the 17x9 or 17x9.5 like you planned.
Bro, its all your preference. IMO 17 for looks and 16 with good offset for autox and sliding around. i doubt you would notice the powerloss if any, between 15s and 17s....poshatch wrote:thanks alot for the info, i havnt gotten a look on what 16's look like so i cant make a good decision on those i see 17s all the time and they seem to fit the wheel well the bestand the only other consern i had was torque, how much torque i would be loosing from going from 15 to 17's noticible?is it a big difference?, because i had planed on using these wheels for auto x and street use and using my stock's and steelies for drift events and what not until i got good enough to go bigger
you got it, im refferring to torque lost at the wheels from switching to a bigger size, if its not a huge difference then i will probably go with the 17'sS14toRPS13 wrote:As far as losing torque, I'm assuming you're referring to the change in gear ratio with larger diameter wheels. With the proper plus sizing, you'll retain about the same gear ratio and you won't feel any loss in power, ie larger wheels equals lower profile tires. BTW, I have 16's on my car if you're curious as to how 16's looks like on a hatch. Just check the sig.
Ohhh you definitely notice the power loss, which is one of the reasons im swapping. Also braking is decreased as well but its worth it.ag240 wrote:
Rotas never win.OM3GA wrote:rotas
17s
win
big whoopsILoveMyRHS13 wrote:Power loss? No. Wheels taking longer to make a full rotation, yes. Rolling resistance, higher roll-out, etc.
yea thats how i feelcarps13guy wrote:yes, wheels are wheels. but your goal should be the lightest, strongest wheels possible. other than that the only other consideration that should dictate size is what brakes you plan on running, and what rim size and offset can clear those brakes. its all about function OVER form
well thats a yes and a noTheRealNap0le0n wrote:17's will feel different than 15's based on unsprung mass and rotational mass increase...
you car is stock and still slow, rock wheels that look good IMO... as far as drifting goes rock cheap wheels FTW....
btw Z32 brakes fit with steelie 15"s ??
hmm i dont even remember what my wheels look like seeing that i have awesome undamaged hubcaps.... not the gay ones but the cool ones...poshatch wrote:
if you go on 240sxtechnical they got this same info but basically
there are two designs in stock 15" 7 spoke steelies
one of which the back of the spokes is two parrallel lines, and the other is sort of a criss cross of 3 lines, thats just how they look
the parrallel ones wont fit but the 3 line one will, and they only fit the 28mm z32 brakes, the 30mm ones wont clear either unless you space the wheel somehow by about 4 mm
its pretty rediculous how barely they clear
if you go 5 lug so s14 i hear they clear z32 or 300zx will clear for sure 16x8 not badTheRealNap0le0n wrote:hmm i dont even remember what my wheels look like seeing that i have awesome undamaged hubcaps.... not the gay ones but the cool ones...
i'm gunna have to figure out how to make the 15" 5lug maxima steelies work cuz when i go 5 lug i wanna stick with 15" steelies for a while... to save for baller wheels and for teh dorifto purposes
no, the OP said that he has the 7 spoke, as in 7 spoke se alloys. but he has the special alloys with the hollow inside that just barely clear z brakes. there is a thread w/pics on here showing you the difference. ive been looking for a set for a while nowTheRealNap0le0n wrote:btw Z32 brakes fit with steelie 15"s ??
yea i understand how lame it is. never been pulled over until i owned a 240sancosys wrote:Cool to see another Sacramento area guy.
1. Don't F up Sacramento worse than it is to drive a 240.2. If you are worried about the mass of the 17's messing things up look up Brian Harte, guy has been rocking a NA KA for days.
In the end if yours car and do what you like. Happy modding!
Aaron
